I recently read that on iOS (don’t know about Android) Tiktok can steal data from the iphone clipboard.
Do you know if that can happen on Android/Lineage/Iodé ? If so, is there a way the prevent it?
Thank you
Thank you
Not being funny, but the best way to prevent this is not using TikTok, ever.
In Settings → Privacy, there is a switch “Show clipboard access”. In theory, you should then be informed when an app gets the clipboard content. There is however no way to prevent that access in aosp/lineage/iodé.
