Same here, clearing data and cache have no impact.
Disable SE Linux don’t help
Reboot don’t help
iodé App - disabled protection - details - ota.iode.tech - #18 - rx 96kB - tx 25kB
Info: Sometimes iodé app don’t show any connection, anyhow all messangers and browser still work fine.
Thanks, works now
Is there any progress?
I expect, that the reason is the missing signatur of iodeOS on the shift phone (visible via bootloader meaaage).
This is not available on CalyxOS, /e/ and ShiftOS L, where the Fingerprint reader was wirking.
Can you please clarify what issue we are talking about? You are not able to update to newer versions of iodéOS or you are wondering about progress on FP sensor support?
Wondering about 2 things.
- fingerprint sensor support status.
- According my research, the reason is the missing signatur, which will be indicated by a message at boot from bootloader
The fingerprint sensor is now working on Shift8 with the last beta version of IodeOS(v7.6).
The official version of IodEOS has shifted to 7.6, so the fingerprint should work for everyone, now.
Yes, works.
Only at my wives phone (with old 3 buttons) the light will sometimes not switched off immediately.
The fingerprint light, stays some times some seconds on after unlocking.
This is a known issue with the fingerprint firmware. As it only occurs rarely and sporadically, Shift has not yet managed to debug it.
Since the 7.7 version (or maybe was it already the case in 7.6 but I failed to check it), this Trust page is all green. Both Platform and Vendor “Android Security patches” are reported Up to date.
There is only the “custom key” functionality missing, now ![]()
