eSpeak worked fine on my Calyx Pixel 3a XL, but it’s not working on my iode Pixel 8. It says there are 0 voices loaded. It also is willing to load a voice file from the SD card I don’t have. How do I fix this?
Try SherpaTTS, you find it at F-droid
That worked! Thanks! Now, with the new phone, it will speak AND listen!
