Suggestion: add double tap to wake
While we have lift to wake, that ends up turning on my phone a lot when carrying it around. We have double tap to sleep on the status bar at the top, so why not double tap to wake option? I, as I am sure a lot of us, are in their devices a lot and will wear out the power button fast if we don’t have double tap to wake.
Can you try “System Settings > Display > Lock Screen > Tap to check phone” (and disabled “Lift to check phone”) to see if it meets your expectations?
I don’t have “tap to check phone” I only have “lift to wake”. I also disabled “lift to wake” but still no other options appeared. I thought it might be due to OS (found I was on a older version). I was running 6.3 but when I updated to 6.9 no change.
FWIW @rik I tested this on my BraX3 and no option / doesn’t work for me either.
I was just about to ask if I was missing something to get the setting to show on my Brax3
Let me check if this is a hardware dependent feature.
I got confirmation from the developers that it is indeed a hardware-specific feature, and the brax3 does not support tap-to-wake. Sorry to bring the bad news :frowning:
I dont believe its hardware related, it was possible on all of my (Sony) devices but was gone from Android 12 on…
Well I’m just going on what @vince31fr explains :slight_smile: . But maybe it is a combo of “hardware + Android version”? Probably the place to dig around for it being dropped from Sony devices is at at the LineageOS issue tracker:
Bummer. Thanks for checking. And strange we can have tap to sleep but not to wake? Wonder if there is something else we could have other than lift to wake to preserve the power button? Or some configuration for lift to wake?
On my Pixel 6a, a single tap wakes the screen. A double tap on the status bar ( when pulled down from the top) locks the screen. You may want to search for “tap” in your device settings to see what might be available for you…
