i have some issues with Spotify. It does not run well in the background.
Problem:
I still hear the music, but can not controll it anymore via the Android “Dropdown” Menu. I still see the Spotify entry, but can not conmtrol i anymore. Same is with my headphones, i can hear the music but the controls are not working anymore. Spotify does not even show up on the lockscreen anymore, when it “dies” silenty in the background. In google Maps i can not use Spotify anymore, when it “dies”.
My solution so far:
I have to kill Spotify and then reopen it. Then it works for some times. But when i reopen spotify again some hours later, i have the same issues again. It is totally anoying behaviour. I already opt out the battery optimization for Spotify, did not help. Even reinstalling the app did not work.
I found out that the “misbehaviour” of Sporitfy starts when i close a running Spotify instance via the “App Overview” of all open apps. Then i still hear the music, but can not control Spotify anymore via the notification or other third party tools like external headphones.
Same problem here with a Fairphone 5 and IodéOS 5. It seems like a Lineage based OS problem because I have an old OnePlus 5 Pro with e/OS/ on it and the same problem occurs. If someone have a solution it would be a blessing cause it’s really a pain to have to kill the app and re-open it each time you need to use it …
Other annoying thing I have noticed: I can’t start video podcasts, even when I deactivate the video and just want to listen. Every podcast wich was uploaded as video podcast can’t be opened on my device
activating Spotify connect
And no results so far.
I think there’s perhaps something with MicroG and push notification because like h23hx said, switch notification on and off resolve the problem same as killing the app and launching it again …
I think he means the beta update, not final yet. Still have to test if the issues is solved with iode 4.11
. I have other not Spotify related issues with the update (problems with MicroG and apps using google push fcm)
I do have the same issue, and it is not a problem with the Spotify app - same happens with other media playback apps, the media miniplayer gets frozen under certain circumstances. As multiple users reported it on several different devices, it is most likely a problem iode.
