Sony XZ2 lost MAGISK after update to 3.2
the update to 3.2 worked fine, but as last time, root access via Magisk was gone.
Last time, reinstall of Magisk worked, this time, it doesn’t and I don’t know what is wrong.
Since Magisk isn’t signed, it can’t be installed via IODE recovery and adb.
Last time I used the Lineage 19 recovery, since it is possible to install unsigned archives.
What I tried:
as root:
fastboot boot ./lineage-19.1-20221019-recovery-akari.img
Sending ‘boot.img’ (65536 KB) OKAY [ 2.241s]
Booting FAILED (Status read failed (No such device))
the phone is/was visible with fastboot devices
next try:
fastboot flash boot_a lineage-19.1-20221019-recovery-akari.img
Works, I can flash magisk via ADB sideload, but iode won’t start anymore.
So, next step:
fastboot flash boot_a iode-3.2-20221014-akari-recovery.img
I’m back from where I started, since the patched boot image is overwritten.
Where is my mistake?
thanks
Uwe
I finally got Magisk installed.
This time, I patched the iode recovery image with Magisk.
Steps:
  • copy the file iode-3.2-20221014-akari-recovery.img from PC to the phone.
  • In the Magisk app, choose install and select the iode recovery file, after the patch, there is a file called magisk_patched-25200_UNfNB.img. Copy this file to the PC.
  • Boot the phone in Bootlaoder mode, with the extended shutdown menu in iode or via
adb reboot bootloader
The phone restarts and the blue LED is on.
Check for the fastboot connection with fastboot devices.
  • If the phone ist visible, enter
fastboot flash boot ./magisk_patched-25200_UnfNB.img
and restart the phone, now iode is patched and Magisk works
What is magisk and can it solve my right speaker which stopped working after two days of tough sound when I update v4. 7
Magisk is a way to get root access of the phone. It sounds to me that your hardware has a problem.
Did you install an older version?
You ask meanwhile in all kind oft threads the same questions and got some advice, it makes no sense to flood your problem
I faced a tough sound from right speaker after updating iodè 4.7 then stopped working after three days for my Sony xz2 is it soft or hardware can you help me
Thanks alot
