tried to flash a Sony XA2 with the installer and also manually but in both cases flashing fails and results in a boot loop - logs in both cases seem to be similiar - here the log of the manual flash:
mke2fs 1.46.2 (28-Feb-2021)
Creating filesystem with 5242880 4k blocks and 1310720 inodes
Filesystem UUID: 0d1d0c38-d7c3-4f1c-98e5-49313c720495
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Sending ‘userdata’ (180 KB) OKAY [ 0.010s]
Writing ‘userdata’ OKAY [ 0.001s]
Finished. Total time: 0.082s
Bootloader Version…: 1310-0301_X_Boot_SDM630_LA3.0_P_38
Baseband Version…: 1311-2845_50.2.A.0.400
Serial Number…: CQ3000U0M9
Checking ‘product’ OKAY [ 0.001s]
Setting current slot to ‘a’ OKAY [ 0.005s]
extracting boot.img (25 MB) to disk… took 0.084s
Sending ‘boot_a’ (26605 KB) OKAY [ 1.035s]
Writing ‘boot_a’ OKAY [ 0.229s]
archive does not contain ‘init_boot.img’
archive does not contain ‘dtbo.img’
archive does not contain ‘dt.img’
archive does not contain ‘pvmfw.img’
archive does not contain ‘recovery.img’
archive does not contain ‘vbmeta.img’
archive does not contain ‘vbmeta_system.img’
archive does not contain ‘vbmeta_vendor.img’
archive does not contain ‘vendor_boot.img’
archive does not contain ‘vendor_kernel_boot.img’
archive does not contain ‘super_empty.img’
archive does not contain ‘boot_other.img’
archive does not contain ‘odm.img’
archive does not contain ‘odm_dlkm.img’
archive does not contain ‘product.img’
extracting system.img (2104 MB) to disk…ziparchive W 06-10 17:25:04 3278 3278] Zip: unable to allocate 2206216880 bytes at offset 0: No space left on device
fastboot: error:
failed to extract ‘system.img’: I/O error
Rebooting OKAY [ 0.000s]
Finished. Total time: 0.252s
Tried iode v4.8 and v4.10 - any help is appreciated.
