Hello everyone.
I’m experiencing several issues using iodeos on my Pixel 9.
1. Conditions: my earplugs are connected to the phone via Bluetooth (listening to music), and I receive an incoming call. When I accept the sound comes via the phone speaker (not via connected earplugs). However, the phone app (the default one, as well as Fossify, which I mainly use) shows that the audio route is Bluetooth. Switching the audio route doesn’t change anything. After the call ends, it seems like the Bluetooth service is stuck. I think so because when I adjust the volume, there’s a delay of about 2 seconds between pressing the button and the phone reacting. Also, changing the volume level doesn’t change the actual volume (the slider position changes, but the volume doesn’t change). Furthermore, if I go to the Bluetooth settings, it says the settings are not responding. After a reboot, the problem goes away. It then happens again with next incoming call. If I make an outgoing call, the problem doesn’t occur.
2. If “Allow USB connections when unlocked” is selected in the “USB Restrictions” settings, I’m having trouble connecting my phone to PC. After restarting the phone, I can connect it via USB and select "Use USB for” (file transfer, USB tethering, etc.). However, if I disconnect the phone from the PC and reconnect it, I only have a few seconds to select the connection type (file transfer, USB tethering, etc.); otherwise, the list (file transfer, USB tethering, etc.) becomes grayed out, making it impossible to select. When I manage to select the desired connection option (file transfer, USB tethering, etc.) within a few seconds, the phone prompts me to verify my identity, and as long as the device is connected to the computer, I can change this selection. But when I reconnect, the same thing happens again.
