Some Weatherapps(beside the original one) keep shutting down. I have also the same with the tutanota app.
Does anyone know what it could be
Maybe the best is to capture a logcat
$ adb shell "logcat -c && logcat > /sdcard/logcat.txt"
- Start the apps and wait for it to fail
- Press Ctrl+C in the terminal you have
adb
running $ adb pull /sdcard/logcat.txt
Maybe there is some obvious error in there
Send logcat to developer
It was my bad. I wasnt aware that these apps use the android webview and i removed it.
Problem solved
