Smartphone for elderly people
Hi guys,
would you recommend using iodé as a pensionist / elderly human? My grandma is turning 90 and is used to navigate through a samsung galaxy tablet S6 running android 12. And if yes, which phone models would you consider and recommend?
regards
luzi
If she is already firmila with Android then it doesn’t matter which ROM. For the model, take the biggest one
