Hi!
When I have charging control enabled in system settings to limit charging (e.g. limit to 80%) on my FP5 with iodéOS 6.3, then the phone charges only slowly:
- up to 11W (1.2A) at 9V with 18W QC3.0 charger (= 4.2W/1A at the battery)
- up to 7.4W (1.5A) at 4.9V with standard 2.4A charger (= 4.2W/1A at the battery)
When charging control is disabled it charges rapidly, at least with a QC charger:
- up to 17W (1.9A) at 9V with 18W QC3.0 charger (= 12W/3A at the battery)
These behaviours are the same with different 60W cables.
As soon as I turn on charging control in system settings, the charging speed drops to 4.2W (1A) at the battery. When I disable it again, the charging speed doesn’t increase again. I need to reboot to have fast charging again.
I measured charging power, current and voltage with a Chargie device and at the battery with the app Wattz.
My questions are:
- Is it by design that the phone charges that slowly when having charging control enabled? Is that an expected behaviour or a bug (in iodéOS)?
- Is there a way to fix that?
I really would like to use charging control and be able to charge my phone at a reasonable speed. - Does anybody know why the FP5 is not charging with at least 2A with a regular 2.4A charger but only charges at 1.5A?
