Shiftphone sometimes offline
My Shiftphone sometimes is becomes offline. Even though wifi and mobile data are connected, nothing can be transfered. Every request just hangs indefinitely.
When turning wifi off and on again, this doesn’t change. The same goes for mobile data. I can also turn on airlplane mode and turn it off again. The only thing that helps is a phone restart.
My device was recently replaced by a new one. I’ve had this issue with the old device as well as the current one.
Am I the only one suffering from this?
Because I don’t know if this is caused by the phone or by iodeOS, I’ve also asked there. Here’s the link to that topic: Gerät ab und zu offline bis zum Neustart | SHIFTPHONES
is this only with with cellular connection, or with WLAN as well?
Do something change, if you disable 5G?
Have you running a wireguard or other VPN?
Have you changed the DNS service or address?
Both.
I haven’t tried that, but my current provider contract doesn’t include 5G, so it is never connected anyway.
I have Netguard connected which is another firewall software that works over Android’s VPN interface. I have tried to deactivate that when the problem occured - with no change.
Private DNS is set to automatic if that’s what you mean.
Is it possible to disable Metguard?
  1. It can be side effect from the double netfilter (iodé app + netguard)
  2. I usede netguard before I switched to iodé as well. I had several issues with connectivity, especially the DNS seams to be blocked in several cases. I would expect an side effect on netguard. Please report the issue there
Ok, this can make in above setup with double filter, trouble as well (both filters have a delay, so the response runs in timeout before answer.
Check another option for a while and verify the impact.
Apparently this really has SOMEthing to do with Netguard. The last time the problem occured, I was able to get it to work again. But it was weird because the first 5 or so deactivations/reactivations of Netguard didn’t help. But eventually it started to work again.
I didn’t see a general problem with the cascade because I am running the same combination on my old phone and have never experienced the issue there. I’ll observe and report back. Thank you!
