Howdy folks,
my Shiftphone 8.1 came back home today, fresh from repair at Shift. I download iodé installer to my Bazzite Linux and tried to install it but it seems stuck pretty early. I waited for about an hour and am not sure what to do now. Please take a look at my log file and advice:
Erasing ‘avb_custom_key’ OKAY [ 0.008s]
Finished. Total time: 0.015s
Sending ‘avb_custom_key’ (1 KB) OKAY [ 0.001s]
Writing ‘avb_custom_key’ OKAY [ 0.007s]
Finished. Total time: 0.023s
mke2fs 1.46.6 (1-Feb-2023)
Creating filesystem with 4096 4k blocks and 4096 inodesAllocating group tables: 0/1 done
Writing inode tables: 0/1 done
Writing superblocks and filesystem accounting information: 0/1 doneWarning: skip copying metadata image avb footer due to sparse image.
Sending ‘metadata’ (52 KB) OKAY [ 0.002s]
Writing ‘metadata’ OKAY [ 0.002s]
Finished. Total time: 0.020s
******** Did you mean to fastboot format this ext4 partition?
Erasing ‘metadata’ OKAY [ 0.002s]
Finished. Total time: 0.013sF2FS-tools: mkfs.f2fs Ver: 1.16.0 (2023-04-11)Info: Debug level = 1
Info: Trim is disabled
Info: Set conf for android
Info: Enable Project quota
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 429419160 (209677 MB)
Info: add quota type = 0 => 4
Info: add quota type = 1 => 5
Info: add quota type = 2 => 6
Info: format version with
“6.17.7-ba20.fc43.x86_64”
[f2fs_init_sit_area: 714] Filling sit area at offset 0x00600000
[f2fs_init_nat_area: 748] Filling nat area at offset 0x01600000
[f2fs_add_default_dentry_root:1364] Writing default dentry root, at offset 0x29600
[f2fs_write_root_inode:1410] Writing root inode (hot node), offset 0x29000
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029601 (1/2)
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029602 (2/2)
[f2fs_write_qf_inode:1553] Writing quota inode (hot node), offset 0x29001
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029603 (1/2)
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029604 (2/2)
[f2fs_write_qf_inode:1553] Writing quota inode (hot node), offset 0x29002
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029605 (1/2)
[f2fs_write_default_quota:1502] Writing quota data, at offset 00029606 (2/2)
[f2fs_write_qf_inode:1553] Writing quota inode (hot node), offset 0x29003
[f2fs_update_nat_default:1591] Writing nat root, at offset 0x00001600
Info: Overprovision ratio = 0.310%
Info: Overprovision segments = 335 (GC reserved = 329)
[f2fs_write_check_point_pack: 939] Writing main segments, cp at offset 0x00000200
[f2fs_write_check_point_pack:1027] Writing Segment summary for HOT/WARM/COLD_DATA, at offset 0x00000201
[f2fs_write_check_point_pack:1041] Writing Segment summary for HOT_NODE, at offset 0x00000202
[f2fs_write_check_point_pack:1053] Writing Segment summary for WARM_NODE, at offset 0x00000203
[f2fs_write_check_point_pack:1067] Writing Segment summary for COLD_NODE, at offset 0x00000204
[f2fs_write_check_point_pack:1075] Writing cp page2, at offset 0x00000205
[f2fs_write_check_point_pack:1095] Writing NAT bits pages, at offset 0x000003fe
[f2fs_write_check_point_pack:1117] Writing cp page 1 of checkpoint pack 2, at offset 0x00000400
[f2fs_write_check_point_pack:1136] Writing cp page 2 of checkpoint pack 2, at offset 0x00000405
[f2fs_write_super_block:1169] Writing super block, at offset 0x00000000
Info: format successful
Sending ‘userdata’ (97 KB) OKAY [ 0.003s]
Writing ‘userdata’ OKAY [ 0.010s]
Finished. Total time: 0.268s
Sending ‘modem_b’ (185916 KB)
Thx in advance,
the.k
