Security updates on iodéOs 5.8 for Samsung S10e
Hi all, I recently installed the 13.12.2024 release of 5.8 on my s10e and I’m pretty happy with iodeOs! some days ago I got the notification about an update but the updater is not finding any … Looking at gitlab it seems only 4.2 has the new patch… Is 5.8 some kind of beta version and should i downgrade to 4.2 or is the patch for5.8 just taking more time?
Cheers!
is the place where the last versions are.
It is a bit confusing, there a files at Github, Gitlab and this place
Thanks, that’s where I checked and the 4.2 version ja the only one with the current patch. So I was wondering if and when 5.8 will get a patch of If I should change to 4.2…
