I think the problem with broken sdcards started in December. First I thought, it is normal that an sdcard breaks after some time. But till now two new sdcards broke after using them in the s9. I’m using current version 2.3 of iodeOS. After use of sd card of about 1-2 weeks I got message popUp that there is a problem with sd card and I can’t get data out of it. I’m using sd card with mobile storage option.
Below I attached the log file of the s9. There you will find messages like “nullPointerException: Attempt to invoke virtual method ‘java.lang.String android.os.storage.StorageVolume.getMediaStoreVolumeName()’ on a null object reference” and “Failed to find mounted volume for /storage/FFBF-E206/Android/…”.
<<< log_count = 8382 >>>
[03-02 18:35:42.385 10014:10014 E/AndroidRuntime]
FATAL EXCEPTION: main
Process: com.mg.android:jk, PID: 10014
java.lang.RuntimeException: Unable to create application com.mg.android.appbase.ApplicationStarter: java.lang.IllegalStateException: Default FirebaseApp is not initialized in this process com.mg.android:jk. Make sure to call FirebaseApp.initializeApp(Context) first.
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6724)
at android.app.ActivityThread.access$1300(ActivityThread.java:237)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1913)
at android.os.Handler.dispatchMessage(Handler.java:106)
at android.os.Looper.loop(Looper.java:223)
at android.app.ActivityThread.main(ActivityThread.java:7664)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
Caused by: java.lang.IllegalStateException: Default FirebaseApp is not initialized in this process com.mg.android:jk. Make sure to call FirebaseApp.initializeApp(Context) first.
at com.google.firebase.d.j(Unknown Source:45)
at com.google.firebase.messaging.FirebaseMessaging.g(Unknown Source:3)
at com.mg.android.appbase.ApplicationStarter.y(Unknown Source:0)
at com.mg.android.appbase.ApplicationStarter.onCreate(Unknown Source:9)
at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1192)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6719)
… 8 more
[03-03 01:24:06.120 6878:7091 F/libc]
Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 7091 (AsyncTask #1), pid 6878 (com.android.nfc)
[03-03 01:24:06.183 28841:28841 F/DEBUG]
[03-03 01:24:06.184 28841:28841 F/DEBUG]
LineageOS Version: ‘2.3-20220129-starlte’
Build fingerprint: ‘samsung/lineage_starlte/starlte:11/RQ3A.211001.001/eng.vince.20220129.104701:user/dev-keys’
Revision: ‘26’
ABI: ‘arm64’
[03-03 01:24:06.186 28841:28841 F/DEBUG]
Timestamp: 2022-03-03 01:24:06+0100
[03-03 01:24:06.187 28841:28841 F/DEBUG]
pid: 6878, tid: 7091, name: AsyncTask #1 >>> com.android.nfc <<<
uid: 1027
signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
x0 0000000000000000 x1 0000000000001bb3 x2 0000000000000006 x3 00000076ba60c3c0
x4 61601f3a5355445e x5 61601f3a5355445e x6 61601f3a5355445e x7 7f7f7f7f7f7f7f7f
x8 00000000000000f0 x9 00000079b4d64800 x10 ffffff80fffffbdf x11 0000000000000001
x12 0000000000000000 x13 000000000000005f x14 00000076ba60ada0 x15 000000000014ab56
x16 00000079b4dfec80 x17 00000079b4de0780 x18 00000076b91ce000 x19 00000000000000ac
x20 0000000000001ade x21 00000000000000b2 x22 0000000000001bb3 x23 00000000ffffffff
x24 00000076ba60ccc0 x25 00000076ba60ccc0 x26 00000076ba60cff8 x27 00000000000fe000
x28 00000000000fc000 x29 00000076ba60c440
lr 00000079b4d92544 sp 00000076ba60c3a0 pc 00000079b4d92574 pst 0000000000000000
[03-03 01:24:06.206 28841:28841 F/DEBUG]
backtrace:
#00 pc 000000000004e574 /apex/com.android.runtime/lib64/bionic/libc.so (abort+180) (BuildId: c4b58dcff73798c360d98d0eba230b0d)
#01 pc 000000000002e2ac /system/lib64/libnfc_nci_jni.so (android::nfaDeviceManagementCallback(unsigned char, tNFA_DM_CBACK_DATA*)+1236) (BuildId: c3396c5851afe4d71cc0f92d33e79722)
#02 pc 000000000003a018 /system/lib64/libnfc-nci.so (nfa_dm_nfc_response_cback(unsigned short, tNFC_RESPONSE*) (.cfi)+1072) (BuildId: 76d7d2f920653c281dcfd897ae6b13ed)
#03 pc 000000000006c3c0 /system/lib64/libnfc-nci.so (nfc_main_handle_hal_evt(tNFC_HAL_EVT_MSG*) (.cfi)+584) (BuildId: 76d7d2f920653c281dcfd897ae6b13ed)
#04 pc 0000000000071850 /system/lib64/libnfc-nci.so (nfc_task(unsigned int) (.cfi)+296) (BuildId: 76d7d2f920653c281dcfd897ae6b13ed)
#05 pc 000000000009c1c8 /system/lib64/libnfc-nci.so (gki_task_entry(void*) (.cfi)+104) (BuildId: 76d7d2f920653c281dcfd897ae6b13ed)
#06 pc 00000000000b1fc8 /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+64) (BuildId: c4b58dcff73798c360d98d0eba230b0d)
#07 pc 00000000000505d0 /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: c4b58dcff73798c360d98d0eba230b0d)
[03-03 22:09:17.939 7655:28414 E/AndroidRuntime]
FATAL EXCEPTION: Thread-9
Process: com.android.providers.media.module, PID: 7655
java.lang.NullPointerException: Attempt to invoke virtual method ‘java.lang.String android.os.storage.StorageVolume.getMediaStoreVolumeName()’ on a null object reference
at com.android.providers.media.util.FileUtils.getVolumeName(FileUtils.java:837)
at com.android.providers.media.scan.ModernMediaScanner$Scan.(ModernMediaScanner.java:312)
at com.android.providers.media.scan.ModernMediaScanner.scanDirectory(ModernMediaScanner.java:225)
at com.android.providers.media.MediaProvider.scanDirectory(MediaProvider.java:1092)
at com.android.providers.media.MediaService.onScanVolume(MediaService.java:148)
at com.android.providers.media.MediaProvider.onIdleMaintenance(MediaProvider.java:980)
at com.android.providers.media.IdleService.lambda$onStartJob$0(IdleService.java:43)
at com.android.providers.media.IdleService.lambda$onStartJob$0$IdleService(Unknown Source:0)
at com.android.providers.media.-$$Lambda$IdleService$JjwnmffYz-dHZaOMAebPNoWHP20.run(Unknown Source:4)
at java.lang.Thread.run(Thread.java:923)
[03-03 22:10:00.459 28567:29627 E/AndroidRuntime]
FATAL EXCEPTION: Thread-4
Process: com.android.providers.media.module, PID: 28567
[03-03 22:11:18.508 29706:29972 E/AndroidRuntime]
FATAL EXCEPTION: Thread-3
Process: com.android.providers.media.module, PID: 29706
[03-03 22:14:18.624 30008:30117 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 30008
[03-03 22:18:53.568 30212:30443 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 30212
[03-03 22:29:21.596 30524:30997 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 30524
[03-03 22:47:24.635 31093:31851 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 31093
[03-03 23:20:29.522 31890:881 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 31890
[03-04 00:28:31.603 920:3569 E/AndroidRuntime]
FATAL EXCEPTION: Thread-6
Process: com.android.providers.media.module, PID: 920
[03-04 00:55:48.166 28844:28869 F/libc]
Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 28869 (AsyncTask #1), pid 28844 (com.android.nfc)
[03-04 00:55:48.233 5275:5275 F/DEBUG]
[03-04 00:55:48.234 5275:5275 F/DEBUG]
Revision: ‘26’
ABI: ‘arm64’
Timestamp: 2022-03-04 00:55:48+0100
pid: 28844, tid: 28869, name: AsyncTask #1 >>> com.android.nfc <<<
uid: 1027
x0 0000000000000000 x1 00000000000070c5 x2 0000000000000006 x3 00000076ba7123c0
[03-04 00:55:48.235 5275:5275 F/DEBUG]
x12 0000000000000000 x13 000000000000005f x14 00000076ba710da0 x15 000000000084297e
x16 00000079b4dfec80 x17 00000079b4de0780 x18 00000076ba428000 x19 00000000000000ac
x20 00000000000070ac x21 00000000000000b2 x22 00000000000070c5 x23 00000000ffffffff
x24 00000076ba712cc0 x25 00000076ba712cc0 x26 00000076ba712ff8 x27 00000000000fe000
x28 00000000000fc000 x29 00000076ba712440
lr 00000079b4d92544 sp 00000076ba7123a0 pc 00000079b4d92574 pst 0000000000000000
[03-04 00:55:48.249 5275:5275 F/DEBUG]
backtrace:
[03-04 00:55:48.250 5275:5275 F/DEBUG]
[03-04 02:38:44.603 3622:8790 E/AndroidRuntime]
FATAL EXCEPTION: Thread-7
Process: com.android.providers.media.module, PID: 3622
[03-04 06:54:45.196 8809:16849 E/AndroidRuntime]
FATAL EXCEPTION: Thread-5
Process: com.android.providers.media.module, PID: 8809
[03-04 22:14:23.613 16854:32086 E/AndroidRuntime]
Process: com.android.providers.media.module, PID: 16854
[03-05 00:43:13.116 5279:5304 F/libc]
Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 5304 (AsyncTask #1), pid 5279 (com.android.nfc)
[03-05 00:43:13.199 5548:5548 F/DEBUG]
[03-05 00:43:13.200 5548:5548 F/DEBUG]
Revision: ‘26’
ABI: ‘arm64’
[03-05 00:43:13.202 5548:5548 F/DEBUG]
Timestamp: 2022-03-05 00:43:13+0100
pid: 5279, tid: 5304, name: AsyncTask #1 >>> com.android.nfc <<<
uid: 1027
x0 0000000000000000 x1 00000000000014b8 x2 0000000000000006 x3 00000076ba7113c0
x12 0000000000000000 x13 000000000000005f x14 00000076ba70fda0 x15 0000000000d382fa
x16 00000079b4dfec80 x17 00000079b4de0780 x18 00000076b9c5e000 x19 00000000000000ac
x20 000000000000149f x21 00000000000000b2 x22 00000000000014b8 x23 00000000ffffffff
x24 00000076ba711cc0 x25 00000076ba711cc0 x26 00000076ba711ff8 x27 00000000000fe000
x28 00000000000fc000 x29 00000076ba711440
lr 00000079b4d92544 sp 00000076ba7113a0 pc 00000079b4d92574 pst 0000000000000000
[03-05 00:43:13.218 5548:5548 F/DEBUG]
backtrace:
[03-05 00:43:13.219 5548:5548 F/DEBUG]
[03-14 20:57:13.131 4018:4018 E/vold]
Failed to find mounted volume for /storage/FFBF-E206/Android/data/org.thoughtcrime.securesms/cache/
[03-14 20:57:13.132 4018:29739 E/vold]
Failed to find mounted volume for /storage/FFBF-E206/Android/data/com.nextcloud.client/cache/
