Samsung Tab S5E wifi
there is a bug in the wifi… in iode 6.
can no longer connect to the router.
and that’s a big problem with a wifi tab.
Location is deactivated… is still shown as active in the top left of the bar.
At the bottom of the bar the camera is hidden by the back button
I didn’t select microG… why was it installed and activated anyway?
after 2 hours of trying… microG deactivated… the WLAN works now… but it takes a long time to connect
too early to celebrate… it worked once…
I have no problems with my Tab S5e with WiFi.
My Tab S5e works as expected.
So done … she still had the beta on it … since WiFi didn’t work there she couldn’t update.
I have now installed the current version … and it works as it should
