I’ve got my hands on a S23 envisaging it replacing my pixel 5.
To date I trawlled through the apps and initially installed aurora , fdroid, protonpass in personal and secure folder. Then removed all installed app permissions, replace with alternative , installed banking and a lot of other default apps in secure and only a few necessary ones in personal.
Now I’ve noticed that ronnz98 has posted os 6.9 so,
Q1 How do Install this zip file, can the web installer be used and how , or is there another simpler way (I’m not confident to use adb method
Q2 Is there a chance of ronnz98 good work of being official , and use the web installer.
Q3 Is ronnz98 or other developers looking at 7.4 and future os’s being available
One big warning: Samsung has blocked VoLTE for all of their devices if a custom ROM is used. So if you need 4G / 5G telephony you will need a device from another manufacturer .
For @ronnz98 's builds he should post basic instructions but basically you can follow LineageOS install, just replacing the main zip from him for the LineageOS build.
It is very unlikely it would be added as an official device (since again no Telephony )
So I’ve removed Google and Samsung accounts, only that the Samsung removal also removed the secure folder.
I had anticipated that and Install island to create work profile, surprise was I had work profile and secure folder. I expect island would delete secure folder, that happened when I removed Samsung account.
