Samsung Galaxy Tab A - SM-T580 (gtaxlwifi), SM-T585 (gtaxllte), SM-P580 (gtanotexlwifi), and SM-P585 (gtanotexllte) for iode 5.18
First test builds for iode. Please test and provide feedback!
iode-5.18-20251201-gtaxlwifi.zip
iode-5.18-20251201-gtaxllte.zip
iode-5.18-20251201-gtanotexlwifi.zip
iode-5.18-20251201-gtanotexllte.zip
Please see sources and install instructions including recovery here:
https://xdaforums.com/t/lineageos-19-1-for-sm-t580-gtaxlwifi-sm-t585-gtaxllte-sm-p580-gtanotexlwifi-and-sm-p585-gtanotexllte.4432957/page-83#post-89732525
Use it at you own risk!
Please support the developer(s)!
diode
December 3, 2025, 2:02am
2
Thank you for this, this is great! But I am confused: where is the recovery? My gtaxlwifi is running stock.
woaloo
December 3, 2025, 5:22pm
3
I think that you will have to install TWRP before (with Odin).
diode
December 3, 2025, 7:17pm
4
woaloo
December 4, 2025, 12:09pm
5
@ronnz98 , so I just have to install TWRP 3.7.0.9, install the good iodé zip file, and it will be OK ?
I already have LineageOS 16 (Android 9) on my SM-T580 (gtaxlwifi)
woaloo
December 5, 2025, 12:45pm
6
I’ve tried Iodé on my SM-T580. It’s not working.
I’ve formatted DATA, wiped Cache, Dalvick Cache.
Install is OK, but when the tab reboot, it stay stuck on logo screen : IODE
take latest /e/OS version then, same sources:
Shizzle
December 22, 2025, 9:09am
8
I get the same issue. Unfortunately, the /e/ Roms are no longer available.
I tried to flash it with the latest oficial version of twrp. I made a clean flash and deleted everything and formatted data. Even so, it got stuck in the boot animation and it didn’t boot. I tried reflashing it again but it didn’t work either. Can I get some help?
You can use the /e/OS-ROMs, iode seems not to work though same sources used
Shizzle
January 22, 2026, 7:26pm
12
Works! Thank you so much!
ronnz98
January 22, 2026, 7:32pm
13
Which version did you install?
Shizzle
January 22, 2026, 7:54pm
14
The newest from december for gtaxlwifi
