I am very happy with iodeOs and already use it on the Sony Xperia XZ3 and on the Pixel 4. Now I would like to flash it on a Samsung Galaxy A5. But I have the following problem:
with the key combination Vol down+Home+Power I can’t get into the download mode
I can work around this with < adb reboot download >
the device boots directly into download mode
the command < heimdall flash --RECOVERY recovery.img > is also executed successfully
after flashing directly I press the buttons Vol up+Home+Power and the device boots normally into the Stock Rom
with the additional command < --no-reboot > the progress bar stops a few pixels before the end
with the command < adb reboot recovery > shows error: no devices/emulators found
but with the key combination Vol down+Home+Power I can then exit the download mode
It looks like the key combinations have no effect on my device.
The latest stock firmware is installed. OEM and USB debugging are activated.
Do you have any idea how I could solve the problem?
Many thanks and best regards
Michelsgung
So you have a defective volume-down button, it seems, right?
I have put custom ROM’s on multiple A5’s and they all booted fine in download-mode.
With Odin 3.13 in Windows putting a custom recovery on them is done in a few minutes. Also I recommend TWRP as custom recovery. You can load any ROM from there (put the ZIP on microSD) including Iodé.
Of course OEM-unlock should be switched on in developer settings.
Yes, I now know that the home button is damadge. But the problem without homebutton, i cant start the recovery after loading it. I will repair it and try again soon.
