Samsung A52s - noticed flickering with display - iodéOS 6.12
Hello all, since last update, I noticed a remarkable flickering with the display. It happens globally, on home screen and with any app opened. I wonder if it’s a hardware issue, or maybe related to 6.12 version ? Any feedback appreciated, thank you :slightly_smiling_face:
The malfunction disapeared the next day after I posted. An other arcanum in the field of liberated ROMs :slightly_smiling_face:
I hope it is OK I marked your update as the “solution” even though we never reliably understood the issue :slight_smile:
Hello Rik, thanks you did very well :ok_hand: Not easy to find accurate words to describe the phenomenon, fortunately it was transitory. Gratitude for your generous activity here :slightly_smiling_face:
