Hi Iodé team,
It bas been now 3 weeks that I installed the IODE custom ROM. It is a daily use OS and perfect for privacy.
Simple to install also. Sincerly it is a very good job. Thanks Iodé team.
The application chosen are privacy oriented.
I have noticed some features that you can add or maybe they are already on your lists priorities :
- Application running un background even if they has been closed. I am using greenify app to force app to close. I guess it will be good to have an Iode feature for that.
- having the possibility to blocks mores API requests. I have that you are already working on it.
Happy to help if needed
Have a good day
