Request unofficial builds for unsupported devices
I added it to my list, as I build for the Moto G (2024) fogo, Moto G34/45 fogos, and Moto Edge (2024) avatrn already. As 7.5 is in beta now, I’ll wait to build until that is released.
Fantastic work, thankyou for providing these builds! :slight_smile: Too bad I am out of luck with the Xiaomi 12 but oh well, I’ll see if I try a GSI or play safe with LineageOS. Thanks for trying with the next builds!
Motorola - Moto G10 - Capri - @Duper - 23.2 - LineageOS Downloads
Hi there,
Any chance of an official build for above device? Official current LineageOS available.
Thank you
Already been requested, attempted and failed: see this post. Will be retried for the next few build runs
Hi Pete,
Thanks for your reply. Look forward to testing.
Cheers
Sorry, my mistake: the build I tried and failed last month was for cupid, not capri. But a new build run is in progress which includes both :crossed_fingers:
Where do I find new builds?
When they are done they will be at https://iode.lineage.microg.org/. Unfortunately the first attempt to build failed because some of the iodéOS sources had not been made visible. The next attempt will happen after the LineageOS for microG 22.0 builds are done. You can check on build progress in the ’ MicroG LineageOS builds’ Matrix channel
Done. You can find miami and avatrn here with my other Moto builds: Motorola Unofficial Builds
Manufacturer Model Code Name Requested by Current LOS Version Links
Xiaomi Redmi Note 10s rosemary @jahid015 23.2 (official) LineageOs official device info
It would be helpful if someone officially maintain this device. Cause its already maintained by Los with 0.1℅ bug and I know the Dev.
I don’t think the iodé team have the resources to maintain any more official devices. I will try adding this device to the list of devices that I make unofficial builds for, but no promises that it will work. Even if it does work, I’m not in any position to provide any kind of support: all I do is make builds when time and resource availability allows.
Okey bro :heart:
New builds available now for
  • v7.5: cupid, rosemary
  • v6.15: B2N, DRG, fajita, mata, PL2, payton
  • v5.24: billie
Builds in progress for kebab, lemonades, capri (v7) and NB1 (v6)
Flashing guide same as lineageOs for Rosemary?
I assume so
EDIT: Unfortunately the builds for these devices failed due to breaking changes made in the upstream LineageOS repos since the iodé sources were pushed. Let’s hope for better luck with 7.6!
Thanks for trying. Better luck next time for Capri.
Interesting both LOS and Murena have current builds. I dont really understand the build process though…
Amazing, thankyou :slight_smile: I will report back when done with testing!
Also, can you add the Xiaomi 13 (fuxi) to the build pool? If successful, I will convert this device to Iodé as well!
Feedback: Successfully flashed all working good in Rosemary.
