Request unofficial builds for unsupported devices
just a question, which recovery, boot, dtbo images do i use for this unofficial iodéOS rom?
By the way, is this rom based on lineage 22.2 or 23.0? Because i want to evade using android 16, does this rom support locking bootloader?
I think @ronnz98 typically recommends using the corresponding Lineage components for the build. iodé 6.8 is Android 15 / LineageOS 22.x based.
New builds available at <link removed>:
  • 6.9 for B2N,fajita,mata,NB1,PL2
  • 5.18 for billie
New builds available at https://iode.lineage.microg.org (note the changed download URL)
  • B2N,fajita,mata,NB1,PL2
Future builds for these devices should be available as OTA updates: thanks @rik for making this happen :slight_smile:
Unfortunately no new build for billie: the upstream LOS sources have had ‘build-breaking` changes since the Iodé 5 sources were pushed. With luck this device will get a new build when Iodé make their next release
Manufacturer Model Codename Requested by Current LOS Version Links
Motorola moto X4 payton @Alex 22.2 Info about payton | LineageOS Wiki
I’ve just kicked off a build of Iode 6 for this device. If it goes OK, I’ll add it to the list for future build runs.
I’m afraid the build has failed, and I’m not sure why. Maybe because of upstream changes since the Iode 6 sources were pushed. I’ll try again when the Iode sources are pushed next time.
Hi @ all, who know much better than I might ever do…
I am running a OnePlus 13 (dodge) on LineageOS 23 (A16) as a daily driver. It’s running fine with no major restrictions, but i would like to switch to IodéOS due to the improved privacy.
A microG-LineageOS is available as well ( dodge ) and I therefore would ask for any advice or estimate or even a build for my OnePlus 13.
Thank you for your attention!
The LineageOS for microG build would be a good place to start as there is no iodéOS build (official or unofficial) available for it (yet). I should declare here that
  1. I use LineageOS for microG rather than iodéOS on all my devices, because I don’t need the extra good stuff (network blocking, own brand browser etc.) that iodéOS adds;
  2. I am one of the maintainers of the LineageOS for microG (though I have been involved with iodéOS for a while, and fully support what they are doing).
OK, great (not so great for Iodé, but…) for me. As I have installed microG via F-Droid, I assume I am quite on track. THX!
I will however watch Iodé’s development and reconsider my actual setting if any changes might come :grinning_face:
PLEAE HELP!!! lol @rik
Need an install for OnePlus 12 please. Can anyone help with that?
Also… My kid’s tablets:
Samsung Galaxy Tab S7 FE 5G (Says it’s not supported)
Any help is greatly appreciated.
Thanks’
Michael
That devcie is officially supported by LineageOS (at version 23.2). So making a an iodé 7 build for he device should be pretty straightforward. (Note I am not volunteering myself: I have enough on my plate just now. But maybe someone else will pick this up and make a build).
Not officially supported by LineageOS, and the unofficial build published on XDA doesn;t seem very stable, and I couldn’t find the sources and vendor blobs, so an iodéOS build for this device is a long way off - sorry!
I also looked at this, it is even worse for the “5G” model, as the not very stable unofficial builds are only for the “wifi only” model. I think it is very likely this “5G” version does not have an unlockable bootloader: @mcljr had separately notified me their tablet is a SM-T738U (that maybe doesn’t even have the same SOC), whereas the “wifi only” model that has a few unofficial ROMs for it is the SM-T733. Reference: How To Guide - Root the Galaxy Tab S7 FE (Works with A12) | Page 4 | XDA Forums
I found an old tablet and wanted to try it out.:.Samsung Galaxy Tab A 8.0 (2019)
Also not compatible with the installer. Does anyone have any recommendations on a tablet that is compatible with the installer?
I am 0 for 3 at the moment and am becoming frustrated with the process.
Thanks in advance
Only official builds are integrated in the graphical installer, you can see this chart for official builds: iodéOS official supported devices - iodé
Unofficial builds need to be bootloader unlocked and have a fully functional LineageOS port and kernel source, firmware blobs, etc available. But the Samsung Galaxy Tab A 8.0 (2019) doesn’t have those available. I was actually just looking in the last few days too since I have access to one of those.
I may try the GSI build for it when I get some time.
OK - change of plan. I’ve added OnePlus 12 waffle to my list of devices to try building. Should happen in the next couple of days.
Now available for download from https://iode.lineage.microg.org/waffle/
Install by following the installation instructions on the LineageOS Wiki
Note that this build has not been tested at all: use it at your own risk.
lease let us know how it goes. If it works OK, then future builds should appear as OTA updates. Good luck!
I’d like to sell my Unihertz Titan (UFS) running iodeOS 5.2 (GSI). Am I breaking any rules by listing it on eBay like this? Unfortunately, there’s no maintainer for the device, so I have to manually add the keyboard files to the Android tree myself with every update.
Have you tried running the GSI on the device? (I don’t know much about this device, but a qucik search of XDA Forums indicates that it should be able to run GSIs, and it’s in the list of devuces supported by the iodé GSI
Possible problem with Bluetooth on 7.3 builds: see this post
EDIT: I’ve now tested on pdx235, and BT seems to be working fine in our 7.3 builds. So, false alarm, and apologies for the panic:
