Before doing any mistake I come to you to clarify a question I have about relocking the Fairphone 4 (build 20230905) bootloader.
For now I don’t have installed iode OS and don’t have flashed any avb_custom_key. When I do fastboot flashing get_unlock_ability I have (bootloader) get_unlock_ability: 0. So now if I install iode OS will have the possibility to relock de bootloader by flashing the avb_custom_key or not ?
After unlocking the bootloader of my FP4, fastboot flashing get_unlock_ability returns (bootloader) get_unlock_ability: 1. So I follow all iodé instructions and use de flash_all.sh script and relock my bootloader and all works perfectly fine. I can now use iode with my bootloader locked and I’m pleased with the OS.
