right now im trying to move from /e/os to iode OS and im unsure if its safe or not to move.
Android Security Update - 1st march 2026
Vendor Security Patch Level - 5th december 2025
build number incase it matters is - BP1A.250505.005
also incase it matters /e/OS v3.6 im on right now
and yes i want to lock the bootloader if possible too.
Which device have you got
Yes, you can lock the bootloader, check here: iodéOS official supported devices - iodé
klic
5
Is iode already on security level of April?
I always have trouble to find this data
no, march if i remember corretcly. If you’re running away from cia, nsa and mossad use grapheneOS or no phone at all.
rik
7
All of this matches with iodéOS 7.4 (yes 7.4 is the March security update also).
It is very good to confirm, you should be cleared to install iodéOS!
