Couldn’t tell whether it’s better than any of the others.
Scanns fast and precisely. Looks pretty minimal. Allows you (if you activate it) to see the history of previously scanned codes. Can create codes as well. Can scan codes from stored images.
Really don’t know what else I could possibly be missing.
Ha!
I was aware of the cropping functionality. And know that you explained it is obvious. But I really didn’t know what that was for (didn’t give it much thought before though). Thank you.
I had previously used the QR Scanner (PFA) from SECUSO.
It’s very good.
But the Binary Eye won me over as it’s better in low light and the biggest advantage is that it has a zoom function.
I often went crazy with the QR scanner because you have to go away with your smartphone because you can’t zoom
