Hello there,
I’m very new to custom ROMs and unfortunately had a very disappointing experience with trying to install iodé OS 5.1 on my Fairphone 3+.
First of all, on the iodé website it says, that the Fairphone 3 is supported by the installer. When I opened the application (version 2) it told me, that my device is not supported. I also tried the installer v1 which advised me to download the newer installer. So far so sad for me.
After that, I made myself familiar with adb and fastboot. I was very positive in the beginning that the install would go well, but I ran into some problems. I want to make some remarks about the manual install for a total beginner:
- From https://iode.tech/installation/ i get to FP3 · master · ota / release · GitLab . I’m not completely sure if these are the right installation files because in the instructions in GitHub - iodeOS/ota it says something about fastboot files under this link: Release iodéOS 4.x for Fairphone 3 · iodeOS/ota · GitHub. There are also another bunch of files under “releases” for iodé 5. I downloaded the iodé 5.1 fastboot zip (Release iodéOS 5.x for Fairphone 3 · iodeOS/ota · GitHub). All these files and instructions are quite confusing for a complete beginner.
My question at this point: do I have to use the v5.1 fastboot installation files or the ones under ota/release v5.3?? Are these also a fastboot installation and how do I do it?
Important details I want to mention here that are not written in the installation instructions:
- After installing adb/fastboot (under Windows): check Windows Update → Advanced options → Optional updates for the USB drivers for the bootloader and something like
- After reboot (after unlocking the bootloader) enable USB debugging again and return to fastboot mode (adb reboot bootloader). THEN start the install script (at least that’s how I did it).
After two times trying to install with “./fastboot file.bat” my phone was stuck in fastboot mode and the current-slot: INVALID (after some trying with fastboot getvar current-slot and fastboot --set-active=a or b). I was able to go back to either of these slots but I was still stuck in fastboot mode.
Also, I had no chance to get into recovery mode using all options I could find e.g. to press the buttons or from the fastboot menu.
In the end, I installed Fairphone OS, but I’m quite said I can’t have iodé OS on my phone yet. So far I was really amazed by this OS and it seemed the best option for me besides /e/ OS. I would really like if somebody could give me advise on how to try a different approach.
