Problem with indoor locations using iodéOS
I am using iodéOS on my Fairphone 4 and I experience the problem that the FP4 is not able to find locations when I am indoor (house, mall, …). I would expect that the microG services are able to offer Wifi-based and cell-based locations but it does not seem to work.
Is this a known issue?
I found: Mozilla Location Service is retiring · Issue #2237 · microg/GmsCore · GitHub
I sounds as if MicroG only uses GPS and does not have a “helper”-service anymore. Could this be the problem?
I’m using this: https://beacondb.net/
Thank you very much.
It seems to work quite well.
The latest microG beta release (0.3.3…240913) allows use of either positon or beacondb as the 'online location service. I’ve been using positon fr a while, with no problems
What does “position” mean in this case? A local database of last locations and wifi networks?
It’s the Positon location service - see https://positon.xyz/ - an alternative to the defunct Mozilla system or the beacondb.net service mentioned above
