POCO f7 onyx
I would like to kindly request an official iodeOS build for the POCO F7 (Onyx). Thank you for considering support for this device.
There is no official LineageOS support for POCO F7 - see Devices | LineageOS Wiki #xiaomi - so it would not be straightforward to make a build of iodéOS (or any other LineageOS-based custom ROM).
There was support for a device codenamed onyx: the OnePlus X, but the last LineageOS version supported was 14.1 (Android 7.1) which can’t be used as the basis for iodéOS builds
There are some unofficial custom ROMs currently available for this device:
https://xdaforums.com/f/xiaomi-poco-f7-redmi-turbo-4-pro.12935/?prefix_id=33
crDroid is not LineageOS :slight_smile:
I have iodeOS on my Moto G52 and I am very satisfied with it. That is why I would like to request an official build for the POCO F7, because I trust the iodeOS developers.
I am aware that there are other custom ROMs available for my second phone, but I do not want to give up something that works so well. I have great respect for the iodeOS developers, who genuinely strive to deliver a very high-quality product.
crDroid is also a LineageOS based system, so iode builds can theoretically be performed
Yes, if you can access the needed source and kernel code, and the biary blobs. For officila LOS devices, these are all in the LOS and TheMuppets github repos, and no manifest is needed. For 7nofficial LOS builds, these need to be tracked down and s local manifest cr3ated.
That’s why I said it is not straightforward :slight_smile:
Check this build:
