Hi
Thanks to everyone for your effort!
I am new to alternative ROMs and don’t quite understand a few things, would be great if someone knowledgeable could clarify (yes I’ve looked through FAQs and the forum
Lets say a device is past EOL, what security updates are still delivered from iode? Do I get it right, that hardware vulnerabilities would have left to be open, because they are manufacturer-dependent, while software security keeps up to date, because iodeOS is updated longer than stock-Android? If so, past EOL use via iode is basically a better gamble than past EOL use with stock-OS, but still a little gamble, because of potential hardware issues, correct?
Also a little gamble, because of delayed updates, compared to Google or Graphene?
Is this hardware problem the reason that Graphene is not offering support past EOL?
Also: I am regular use and no government or cartel is after me, so how likely are such hacks anyway?
(This topic should be more clearly answered in the FAQ, I think) -
apparently things changed recently with AOSP and Android 16
(Will iodeOS be affected when AOSP will be closed source?). Sony is recommended there, maybe as a joke. Are there any manufacturers that open source their hardware code? I don’t want to make the switch to iode only to find out in six months, that my pixel 5 is no longer security-updated. In this case I would consider buying another phone where longterm support would be more likely. Recommendations?
Generally my p5 does all i need and I would like to run it as long as possible.
Thank you
