Hey, can the bootloader currently be locked after installing the latest (6.6 version).
Some details of the build you are on usually helps. But if you got the install zip from this other thread, then no. You cannot relock. It says so in the instructions.
I see, thanks. Better wait for official support if it happens for the 9
