Evening all, updated to 7.4 today ( stable ) and now the google camera app is crashing,
Version is showing as 10.3.183.888945295.14 in Aurora, tried restarting phone, clearing cache and reinstalling but no avail, any ideas?
Thanks in advance
Thanks in advance
So i was working on 7.3 right?
Yes mate was working fine, updated to 7.4 and crashes every time I try to open it
Same here, crashing all the time.
A fixup beta build has been pushed. Could you test it ? To install the beta : Updater → preferences → Show Beta updates.
That worked; thanks for the quick reply and update!
It Works! Thanks for the super fast fix! Just curious if the issue was because of Google changes
Not because of google changes : a small glitch was introduced when rebasing and reworking things a bit.
Tested and working!
