I am trying to install iode os on my pixel 8.
Unfortunately the installer isn’t available yet for the pixel 8. So a tried it manually.
The first steps I got working.
unlock oem, activate adb and flashing unlock.
When hitting flash-all.bat in the extracted folder there is nothing installed. When rebooting still the stock pixel os is on the phone. What am I doing wrong?
see the log below
Setting current slot to ‘a’ OKAY [ 0.069s]
fastboot: error: ANDROID_PRODUCT_OUT not set
< waiting for any device >
Finished. Total time: 26.286s
Warning: skip copying abl image avb footer (abl partition size: 0, abl image size: 1785856).
Sending ‘abl’ (1744 KB) OKAY [ 0.047s]
Writing ‘abl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl1 image avb footer (bl1 partition size: 0, bl1 image size: 16384).
Sending ‘bl1’ (16 KB) OKAY [ 0.002s]
Writing ‘bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl2 image avb footer (bl2 partition size: 0, bl2 image size: 536576).
Sending ‘bl2’ (524 KB) OKAY [ 0.015s]
Writing ‘bl2’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying bl31 image avb footer (bl31 partition size: 0, bl31 image size: 106496).
Sending ‘bl31’ (104 KB) OKAY [ 0.003s]
Writing ‘bl31’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gcf image avb footer (gcf partition size: 0, gcf image size: 8192).
Sending ‘gcf’ (8 KB) OKAY [ 0.002s]
Writing ‘gcf’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa_bl1 image avb footer (gsa_bl1 partition size: 0, gsa_bl1 image size: 32768).
Sending ‘gsa_bl1’ (32 KB) OKAY [ 0.006s]
Writing ‘gsa_bl1’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying gsa image avb footer (gsa partition size: 0, gsa image size: 348160).
Sending ‘gsa’ (340 KB) OKAY [ 0.011s]
Writing ‘gsa’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying ldfw image avb footer (ldfw partition size: 0, ldfw image size: 2392064).
Sending ‘ldfw’ (2336 KB) OKAY [ 0.060s]
Writing ‘ldfw’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying pbl image avb footer (pbl partition size: 0, pbl image size: 49152).
Sending ‘pbl’ (48 KB) OKAY [ 0.002s]
Writing ‘pbl’ FAILED (remote: ‘No such file or directory’)
Warning: skip copying tzsw image avb footer (tzsw partition size: 0, tzsw image size: 7917568).
Sending ‘tzsw’ (7732 KB) OKAY [ 0.187s]
Writing ‘tzsw’ FAILED (remote: ‘No such file or directory’)
Rebooting into bootloader OKAY [ 0.002s]
Finished. Total time: 0.005s
OKAY [ 0.204s]
Finished. Total time: 0.205s
Press any key to exit…
PS E:\iode-5.0-20240314-shiba-fastboot\iode-5.0-20240314-shiba-fastboot>
