Pixel 6 not reacting reliable to hard and soft buttons
I have a problem with the hardware and software buttons/icons on a pixel 6. I use bigger icons and bigger text but the problem remains even with standard size settings.
When trying to touch the top right icon in the apps overview i mostly get a A and the scrollbar displayed. Its hard not to hit the second right or the right one from the second line.
Now since the update to iode 6.2 the on/off button wakes the phone only when pressed for a pecific time. Short press does not turn the screen on, long press turns the light on. The ‘real’ on is something in between. This worked reliable in the versions before.
Also the software buttons do not work correctly. The home button ‘O’ works like 50% of the time, and to quit the browser i have to press back ‘<’ for all the pages i have visited. The third button mostly does not work, even when the are apps in the background.
Maybe clearing the cache or reset the settings of the launcher would help but in the recovery there is no option to format cache like it was before.
Is there a way to clear or reset the settings of the launcher / display / keyboard app on the os?
