Since upgrading my Pixel 4a to iodé 7 (presently on 7.5-20260427-sunfish) I’ve noticed occasional reboots, which I guess means it’s crashing. How can I get more detailed information about these events in order to report them somewhere?
So was stable on iodéOS v6.x previously, and then after the v7.x upgrade it became unreliable, or only after the recent v7.4 > v7.5 upgrade the issues began occurring?
There is now an “auto reboot” schedule you can set under “Settings & Privacy” can you make sure that didn’t get enabled somehow
Assuming that isn’t the case, I am not immediately sure of the best way to get relevant logs, I’ll check with the team and post back if they have some good advice.
Yes, I’m pretty sure it started happening after upgrading to v7 in general. Auto-reboot is definitely disabled.
