Brax3 this unit will not connect to the internet, t-mobile shows 5g available, but somehow i cant figure out how to connect to the available data network. Also every youtube video stops in about a minute with an error code, in wifi mode only of course.
Go into settings, and then Internet, and SIM, and see if the switch to use Mobile Data is on.
Yes i have done that. Thank you.
Go inside the SIM settings, then scroll down to “Access Point Names”. For T-Mobile in the USA you should have fast.t-mobile.com and make sure it is selected.
