OP9Pro - Device State Locked
Hallo,
I would like to switch to Iode on my OnePlus 9 Pro (LE2123) but with the installer (iodeOS-installer-v0.3.1-windows) the installation stops as follow.
Installer says:
Checking Bootloader Status
Your device is rebooted mode in order to check the bootloader status
How can I proceed?
Thanks in advance
Gianluca
You will need to issue fastboot flashing unlock from a connected terminal. In Windows you will need to get the fastboot package installed.
