Hi @Mig
so far, I’m using the CustomROM [A]dvanced [XP]erience [OS] aka AXP.OS (A13) with VerifiedBoot and Relocking Bootloader on my OnePlus 6 (enchilada). Is this also possible with your iodéOS ROM?
I don’t think it would ever become “Official” (iodé wouldn’t add an “Officially supported” older device at this point as download server space limitations are already overwhelmed), and if they ever did they would use their own build process, but your “Unofficial” version can be posted here as is for the community!
Hi, could you please share the Iodeos system image for the OnePlus 6?? On the Iodeos website, there’s an image for the OnePlus 6t version, which I assume I can’t use on the standard version. thanks in advance for your reply.
@Mig thanks for the builds in the past. @makalega can you please create a post in this category (you can be the first one to use the unofficial device build template!)
