@mar, both versions of the Tab S5e have a card slot of the same size,
although the SM-T720 (Wi-Fi) can only be equipped with a microSDXC card; the opposite side is blank.
The SM-T725 (LTE) version offers space for a nano-SIM and a microSDXC card.
Commands for Device Properties
Device model: To get the model of your device, type
adb shell getprop ro.product.model -
Device code:
adb shell getprop ro.product.device
- No @mar, you cannot flash iodéOS with Odin!
I would first try to replace only the iodéOS versions. Samsung Stock Firmware 11 can then possibly be flashed later.
Use the LineageOS Wiki as installation instructions
- Tab S5e (LTE) codename / model no: gts4lv SM-T725
- Tab S5e (Wi-Fi) codename / model no: gts4lvwifi SM-T720
Happy flashing!
