Good evening,
FP5, version iodéOs 5.6, iodé premium account:
limited wi-fi connectivity, no mobile data Orange Belgium network.
thank you for your help
The Connectivity Check Server is maybe down or have Problems. Deactivated this Option the ! and Message is go away.
Shift 6mq and 5.6 with Premium Family.
thanks for that, @Revan335, i notified the admins.
The problem seems to be solved. Disconnect, reconnect wifi and mobile data, reconnect, and it should be fine.
Merci
Maybe we have the same Problem again. Its the same Situation without Connectivity Check its working.
