Hey there,
I recently switched from a Samsung Galaxy to a Fairphone 4 and found out that Netflix doesn’t work anymore.
The app starts and shows the “Netflix” banner, but after that nothing is happening. The banner doesn’t disappear and after a few moments, I get “Device failure occured. Please restart your device and try again (501.-172)” (https://help.netflix.com/de/node/125644). But a restart doesn’t help.
I checked via logcat, but I’m not very experienced with reading logcat error messages. So maybe anyone is able to find the problem? The last line with “selinux - denied - untrusted_app” may be the reason, but I don’t know how to fix this.
05-13 16:20:57.165 W/ziparchive( 7518): Unable to open '/data/app/~~nmjhtU8ReBz3Ckv6RytWCA==/com.netflix.mediaclient-ewZPhpbHdQx0HmwmmhwoYw==/split_config.arm64_v8a.dm': No such file or directory
05-13 16:20:57.165 W/lix.mediaclient( 7518): Entry not found
05-13 16:20:57.166 W/ziparchive( 7518): Unable to open '/data/app/~~nmjhtU8ReBz3Ckv6RytWCA==/com.netflix.mediaclient-ewZPhpbHdQx0HmwmmhwoYw==/split_config.en.dm': No such file or directory
05-13 16:20:57.166 W/lix.mediaclient( 7518): Entry not found
05-13 16:20:57.166 W/ziparchive( 7518): Unable to open '/data/app/~~nmjhtU8ReBz3Ckv6RytWCA==/com.netflix.mediaclient-ewZPhpbHdQx0HmwmmhwoYw==/split_config.xxhdpi.dm': No such file or directory
05-13 16:20:57.167 W/lix.mediaclient( 7518): Entry not found
05-13 16:20:57.170 W/lix.mediaclient( 7518): JIT profile information will not be recorded: profile file does not exist.
05-13 16:20:57.444 W/lix.mediaclient( 7518): Unsupported class loader
05-13 16:20:57.530 W/ServiceManager( 1012): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10311 pid=0
05-13 16:20:57.531 W/ServiceManager( 1012): Permission failure: android.permission.ACCESS_SURFACE_FLINGER from uid=10311 pid=7518
05-13 16:20:57.531 W/ServiceManager( 1012): Permission failure: android.permission.ROTATE_SURFACE_FLINGER from uid=10311 pid=7518
05-13 16:20:57.531 W/ServiceManager( 1012): Permission failure: android.permission.ROTATE_SURFACE_FLINGER from uid=10311 pid=0
05-13 16:20:57.531 W/ServiceManager( 1012): Permission failure: android.permission.INTERNAL_SYSTEM_WINDOW from uid=10311 pid=7518
05-13 16:20:57.531 W/ServiceManager( 1012): Permission failure: android.permission.INTERNAL_SYSTEM_WINDOW from uid=10311 pid=0
05-13 16:20:57.551 W/lix.mediaclient( 7518): Unsupported class loader
05-13 16:20:57.552 E/system_server( 1435): Invalid class loader spec: =UnsupportedClassLoaderContext=
05-13 16:20:57.552 E/PackageDexUsage( 1435): Unsupported context?
05-13 16:20:58.127 W/InputManager-JNI( 1435): Input channel object 'db8195f Splash Screen com.netflix.mediaclient (client)' was disposed without first being removed with the input manager!
05-13 16:22:27.903 W/com.netflix.mediaclient( 7518): type=1400 audit(0.0:78593): avc: denied { read } for comm=4C6F6767696E674167656E74202331 name="policy" dev="selinuxfs" ino=20 scontext=u:r:untrusted_app:s0:c55,c257,c512,c768 tcontext=u:object_r:selinuxfs:s0 tclass=file permissive=0 app=com.netflix.mediaclient
I have a Fairphone 4 with iodéOS 4.1-20230327-FP4
Best regards
Ben
