My issue with iodeOS (previous Calyx User) How to use normal Gcam
I have heard the lead dev has a fix for this, will hopefully get more clarification in the coming day or 2.
I confirm, a fix will be implemented in the next beta build for all supported Pixel devices.
GCam will work, and will be installable from Aurora Store.
Thank you! I’m already on the beta, looking forward to the next update.
I have a pixel 9 and like many I come from calyxOS and after reading this I would like to move on to the beta, how do I do it?
thank you very much for that work
See beta · master · ota / ota · GitLab
As previously announced, a beta OTA has been published for Pixel devices with GCam support.
Whoah, that was fast. I can confirm that it works! :tada:
ive updated to latest beta and still showing as gcam not availabe via aurora? Im on a Pixel 9 Pro if that helps
Are you logged in via Google? If yes maybe try to use Aurora’s spoof manager.
edit never mind, updated pixel camera services and now its let me install
Thanks for help
There is a pixel camera and a pixel camera services available on aurora. Pixel camera app says it is not available for my device (Pixel 8a) while pixel camera services is available (and appears to be installed on my device). What is the difference between these two?
Are you on the latest beta? You need both apps. The services provide features for the actual Google Camera app. You might have to update them first. I currently have version 2.4.800624675.09 of it. Otherwise try the tips I suggested above
Thanks! With regard to the beta, are you asking about Aurora? How does one update Aurora (a pre-installed app)?
Yes, I do have the Pixel Camera services app version that you write here.
