It seems Edge + in USA is equivalent to Edge 40 pro in Europe. ( there are minor differences between the two devices, memory capacity being the most significant one) Would IodeOS work on Edge + in USA?
the devices are slightly different, but use the same build for the SoC: so you can safely use the iodé build for any of the three.
