English version below french text…
j’ai fait tout ce qu’ explique le site ici https://iode.tech/fr/documentation/gsi/
à Guide d’installation après avoir vérifié avec treble le *.img approprié .
Comme indiqué par treble, j’ai téléchargé iode-5.26-20260720-arm64_ab.img et contrôlé le sha256.
Ci-dessous ce que j’ai fait. Maintenant le rédémarrage s’arrête à la vue initiale “iodé www.iode.tech”.
**stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot devices
ZY22H3Z4WX fastbootd
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot flash system iode-5.26-20260720
-arm64_ab.img
Resizing ‘system_b’ FAILED (remote: ‘Not enough space to resize partition’)
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ ^C
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition system_ext_a
Deleting ‘system_ext_a’ OKAY [ 0.009s]
Finished. Total time: 0.009s
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition system_ext_b
Deleting ‘system_ext_b’ OKAY [ 0.008s]
Finished. Total time: 0.008s
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition product_a
Deleting ‘product_a’ OKAY [ 0.008s]
stefan@udombua:~/Dokumente/Telefonie/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition product_b
Deleting ‘product_b’ OKAY [ 0.008s]
-arm64_ab.img
Resizing ‘system_b’ OKAY [ 0.006s]
Sending sparse ‘system_b’ 1/12 (262112 KB) OKAY [ 10.349s]
Writing ‘system_b’ OKAY [ 0.395s]
Sending sparse ‘system_b’ 2/12 (262116 KB) OKAY [ 10.837s]
Sending sparse ‘system_b’ 3/12 (262104 KB) OKAY [ 10.611s]
Writing ‘system_b’ OKAY [ 0.360s]
Sending sparse ‘system_b’ 4/12 (262128 KB) OKAY [ 10.288s]
Writing ‘system_b’ OKAY [ 0.388s]
Sending sparse ‘system_b’ 5/12 (262108 KB) OKAY [ 10.729s]
Writing ‘system_b’ OKAY [ 0.370s]
Sending sparse ‘system_b’ 6/12 (262128 KB) OKAY [ 10.504s]
Writing ‘system_b’ OKAY [ 0.375s]
Sending sparse ‘system_b’ 7/12 (262124 KB) OKAY [ 10.448s]
Writing ‘system_b’ OKAY [ 0.364s]
Sending sparse ‘system_b’ 8/12 (262096 KB) OKAY [ 10.510s]
Writing ‘system_b’ OKAY [ 0.418s]
Sending sparse ‘system_b’ 9/12 (262084 KB) OKAY [ 10.519s]
Writing ‘system_b’ OKAY [ 0.384s]
Sending sparse ‘system_b’ 10/12 (262124 KB) OKAY [ 10.774s]
Writing ‘system_b’ OKAY [ 0.377s]
Sending sparse ‘system_b’ 11/12 (262128 KB) OKAY [ 10.396s]
Writing ‘system_b’ OKAY [ 0.359s]
Sending sparse ‘system_b’ 12/12 (204008 KB) OKAY [ 7.998s]
Finished. Total time: 129.379s **
Peut-être avez-vous un conseil pour moi?
Merci beaucoup!
À plus
Stefan
English version:
I followed all the instructions on the website here: GSI - iodé
in the Installation Guide after verifying the appropriate *.img file with treble.
As indicated by treble, I downloaded iode-5.26-20260720-arm64_ab.img and verified the SHA-256 hash.
Below is what I did. Now, the reboot gets stuck at the initial screen that says “iodé www.iode.tech.”
-arm64_ab.img
stefan@udombua:~/Documents/Phone/Motorola-Smartphone/iode-OS/IMG$ ^C
stefan@udombua:~/Documents/Phone/Motorola-Smartphone/iode-OS/IMG$ fastboot devices
stefan@udombua:~/Documents/Phone/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition system_ext_a
stefan@udombua:~/Documents/Phone/Motorola-Smartphone/iode-OS/IMG$ fastboot delete-logical-partition system_ext_b
-arm64_ab.img
Maybe you have some advice for me?
Thank you so much!
See you soon
Stefan
