Hi everybody, don’t have computer . Look for advice on manual way to use iode’ on moto g32 can’t find any links?
You need a computer, Linux or Windows
Yes, best to borrow someone’s computer with windows or linux and use the iodé installer: installer · master · iode / ota · GitLab
Flashing ROMs with another phone without a PC is also possible. This requires two phones (one on which you flash the ROM (Moto G32 devon) and another that you use as a host via terminal and a USB-C (OTG adapter). But this process is more complex than using a host machine (PC, notebook, laptop).
iode.tech has quietly added additional Motorola devices to its portfolio that are supported with iodéOS 5.8, including
Moto G32 devon
Moto G42 hawao
Moto G52 rhode
A special feature is that the bootloader can be locked again with iodéOS 5.8, as a device-specific AVB_Custom_Key (avb_custom_key-devon.bin) is integrated.
This makes iodé.tech the second renowned custom Android distribution after CalyxOS to enable this additional function. LineageOS 21.0/22.1, Lineageos-21.0-for-microG or /e/OS-U do not offer this feature.
Motorola moto g32 (devon)
Moto G32 devon
After successful installation and relocking the bootloader:
iodé Updater does not update the information
“Last checked: January 1, 1970 (01:00)”
and reports
“The search for updates failed. Please check your internet connection …”
although there is an active internet connection (checked via iode-browser).
Was this G32 problem resolved with a manual update? I’ve just bought one for a play that’s all and was wondering if 6.0 might contain a fix.
