Moto Edge 40 Pro (rtwo) issues
Using the official Windows installer, it’s unable to detect whether the bootloader’s already unlocked and the process is stuck at the bootloader unlocking step (loading eternally). The ‘Next’ button is grayed out thus unable to proceed to the next step albeit the bootloader is already unlocked.
Flashing manually on Windoze, the script forever stops at ‘waiting for any device’ after auto-rebooting into fastboot mode. As expected, bootloop occurs if the flashing process is interrupted.
Originally on the latest firmware (Android 15 security patch level May 2025).
It’s impossible to flash iodeOS to rtwo on Windowz in both ways. Is anyone successful with that?
I had issues like this with Pixel devices when using a USB C to C cable, but it was resolved by going to a slower speed USB C to A cable. It may be worth a try in your case.
I was originally using a C to A cable lol
Not certain then of the issue. Sorry, I haven’t used Windows to flash a phone before, maybe there are some complications there with Defender, etc? (see how outdated my Windows terminology is? :slight_smile: )
Hopefully someone else will comment on flashing using Windows and/or installing to a Moto Edge 40 Pro.
