I’m having this issue of my mobile data not working on my pixel 9 pro xl. I recently bought the phone unlocked and flashed the officially supported image for the 9 pro xl and no matter what i try I can’t get the mobile data to work. I made sure to insert the sim properly and i know for sure because at the top of my phone it says “no service”. I tried messing around with the “preferred network type” and with the “automatically select network” as well. I also tried going to APNs and there is only one option i can choose from and i can’t add my own. I can’t edit that APN either. I’m on US Mobile with verizon. I’m hoping somebody can help me with this issue, thanks!
When you go to “System Settings > Network & internet > SIMs” do you see the Verizon sim? I think your “No Service” comment means it isn’t showing there right?
I also use US Mobile with a Verizon network physical sim. Their online chat support has always been helpful, I suggest you contact them, as the “No Service” is more than just mobile data not working.
