Hi.
I’m currently experiencing the following issue with microg: according to the system settings it is active but according to fdroid and also installed apps which require it, it is not.
Moreover, if I try to install the version I’d like through adb I get an error message warning me that I’m trying to install an older version than the one it is already installed.
Any advice?
