Mein Mangenta APP Update problem
After New Update, APP won’t work. “This app cannot run because the invironment is not secure and your data maybe at risk” :face_exhaling: any ideas?
1:0 for the cat
https://pass.telekom.de/home for Data Volummen WLAN must be turned off, for Crédit *100#:grin: 1:1
There is an iodé beta release that restores “SafetyNet”, so this could be “Cat 1: Mouse 1” to follow on @AlphaElwedritsch’s comment.
But note that beyond SafetyNet, iodé did pass a higher level of “Google Play Integrity” (the “newer” device integrity certification method Google uses) for a few months earlier this year, but with various new blocks it is now back to only passing the “basic” level of Play Integrity. So if your app requires this higher level, it could still be “Cat 2: Mouse 1” :frowning:
To your case, if you don’t want to mess with the beta channel, I believe the next update to iodé with SafetyNet fixed will be not to far in the future, so you could wait for that and then retry.
After the update to 6.6 I tried again, but the mangenta APP does not recognize me by itself as before. I have unblocked three websites ULR, but it still doesn’t work. Login with user name and password does not work either. :person_shrugging:
Let’s see if it works again at some point
I can’t confirm that. I just installed the app and was able to log in with my email and password. At first glance, everything seems to be working fine. (iodésOS version 6.6-20250723-salami)
Please try enabling everything for the Magenta app in the iodés app.
Das kann ich so nicht bestätigen. Habe die App gerade installiert und konnte mich mit eMail und Passwort einloggen. So auf den ersten blick scheint auch alles zu funktionieren. (iodésOS-Version 6.6-20250723-salami)
Versuche bitte einmal in der iodés app alles für magenta app frei zu geben.
Genau das mache ich bei keiner APP. Was wollen die mit meinen Kontakten, Standort, und Telefon. Dafür bzw das braucht die APP überhaupt nicht, für das was man damit machen will. :face_vomiting: Dann mache ich das lieber so wie oben von mir geschrieben.
Für was braucht man die App überhaupt?
OK. Ich habe es mal für dich durchgespielt was nötig ist damit die App läuft, mit dem Ergebnis:
  1. in der iodés app muss cms-cdn.yo-digital.com freigeben sein
  2. in microg muss Cloud-Messaging an sein
Ansonsten mal schauen welche microg (bei mir 0.3.9.250932) und iodésOS version (6.6-20250723) du hast.
@ AlphaElwedritsch
damit verwaltet man seine Telekom Verträge
EDIT: die Cloud-Messaging freigabe kann nach dem login wieder entfernt werden
Sollte ja auch im Browserbasierten Dashboard funktionieren
Ja, tut es. Habe mir im Browser einen Favoriten gemacht, mit dem direkten link dahin, um zu sehen, wieviel Daten Volumen ich noch habe. Dauert 5 Sekunden länger und muss das System nicht verbiegen. Werde ich jetzt erstmal so nutzen und wenn ich Lust und Zeit habe mal den Vorschlag von @Sandra probieren. Danke fürs ausprobieren, was man aktivieren muss.
MicroG 0.3.8.250932 und 6.6.20250723-FP5
Eventuell kann man die Seite als PWA installieren
