I just bought a Iodé phone a can’t login to the Strava app.
It says an error occurred when checking my account data. Has anyone already had a similar issue with this app or any other similar app?
Thanks!
Thanks!
I can login to Strava with no problems using IodéOS 4.1 for lilac (Sony Xperia XZ1 Compact). I have nevr encountered the problem you mention - sorry!
Have you enabled all the Google messaging, Safety net, etc… In microG?
Remember, if you change something, Apps must be installed again to take effect
Safetynet was disabled. I was able to login after that, thanks!!
Great
